General Question about Volume
Discussion in 'Home Cinema Buying & Building' started by Happytab, May 3, 2005.
  1. Happytab
    Happytab
    Jan 10, 2005
    261
    When I watch a movie (or TV for that matter) I always have an issue between the difference in the volume of the audio and the volume of the other sound. My question is, are films made like this. When I go to the cinema I have not noticed a problem with vocals but then the other sound is much higher than I have it at home. I guess what I am asking is - As I have to have the volume at a reasonable level (so not to annoy neighbours and wake up the children) is that why the vocals seem a little quiet ?
    What a load of waffle :boring:
    Anyway - I wonder if increasing the volume of my centre speaker would work ?
    Any opinions ?
  2. Happytab
    Happytab
    Jan 10, 2005
    261
    Somebody answer me - I know where you all live you know :eek:
  3. tim1964
    tim1964
    Jan 9, 2005
    28
    Do you have anything in the audio set-up that relates to adjusting the "Dynamic" range? On my Daewoo it has a setting that can be adjusted up or down to level out the differences in the loud and quiet parts (explosions, talking etc). I had to reduce the dynamic range as I also found the loud too loud with normal speech levels.
