Quantcast
General question about back lit keyboards
MikeKay1976
I am looking for info on backlit keyboards.... wow there is some variation in price.
If i get one which says programmable does that mean if i fire uo elite dangerous for instance i can set it so the keys used in that game are lit up, then i play cod and the keys in that one are lit up etc etc or is it mostly just a bling thing? (In which case i wont bother)
Its a shame gearbest only do us layout mechanicak keyboards as theirs are loads cheaper
Amazon mechanicak gzming keyboards seem to start around £70 and go to £150. Ouch !
MikeKay1976
Picked up a corsair k95 mechanical keyboard for 70 quid. Its not the rgb one but that is ok. The white back
light seems to be programmable .
Its from scan, a refurb but full warranty
Hopefully you won't have the issues I did, with keys losing the lights. I ended up getting a RGB in the end though through returns :)
