General DLP usage question
Discussion in 'General TV Discussions Forum' started by zAndy1, Mar 10, 2005.
  1. zAndy1
    zAndy1
    Nov 26, 2002
    22,001
    2
    5
    163
    +8,432
    Do you have to take the same care with a DLP TV as you do with e.g. an LCD projector? I'm thinking about the bulb. For example it's not advised to switch a projector off and then switch it on again shortly after, is this the case with a DLP TV, does it need time to cool down properly after use before it's ok to switch it back on again? I just want to make sure I don't inadvertently shorten the life of the buld on my HD-D45.
    Cheers,
    Andy
  2. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    Yes just switch it to standby on the RD50 the red light flash's for 30 secs before turning red & you cannot turn the set back on for 2 mins it's to allow the fan to cool down the bulb .Using the mains switch will shorten bulb life unless it has been in stanby for a couple of mins first.
  3. digitize
    digitize
    Same thing for my Sagem50, so I assume it will be the same for the Sagem45 which you intend to buy... and all other DLPs... The clean shutdown and slowstart will help to lengthen the bulb life
    technology works this way - immitate, integrate, innovate...
  4. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
    It should be in your manual. :)
  5. Razor
    Razor
    Dec 15, 2004
    37,567
    2
    +12,435
    LOL.... Thats true. All you need is a pc, an internet line, modem, printer with toner, paper, mouse and keyboard.
    Its that simple.
  6. Chris5
    Chris5
    Mar 21, 2004
    1,288
    63
    Herts., uk
    +179
    My Rd50 just removes the picture for the first 30 seconds, so you can switch it back on again in that time if you want, then there is another 30 second when the set is actualy switching off (1 minute total) it also works the other way, when switching on (again another 1 minute cycle)
