gemstar all in one remote
Discussion in 'Home Cinema Control & Remote Controls' started by johnnyrocker, Aug 20, 2003.
  1. johnnyrocker
    johnnyrocker
    customer of mine has a gemstar videoplus h/set which can be programmed to
    >operate 4 pieces of equipment and also videoplus, my problem is he has now
    >bought a sony slvd900g and the gemstar will not operate it, there are two
    >codes for sony both with 10 variations, none of these work, the
    >instructions say that if the codes don't work to input 00 and search this
    >runs through a further 107 options again none of which work I have tried
    >to find gemstar but I believe they have closed uk support, efforts to find
    >a replacement seem fruitless as as far as I can find out new remotes do
    >not have video plus with led display as opposed to on screen, unless you
    >know different!!!!!!!!! any helpful suggestions appreciated. I really am
    >stuck on this one and any pointers appreciated.
    cheers,
    johnny
    >cheers.
    :hiya:
  2. johnnyrocker
    johnnyrocker
    not one person in this gigantic forum got any idea? come on guys!!!!!!!!!!:confused:
    cheers.
    johnny:nono:
