Gemini Remotes
Discussion in 'Home Cinema Control & Remote Controls' started by mikatt, May 17, 2005.
  1. mikatt
    mikatt
    Dec 22, 2003
    178
    Hampshire UK
    +6
    Hi Does anyone have any experience with the hardbutton Gemini learning remotes that Asda sell I need it to be able to operate a Humax PVR 8000 as well as TV video and DVD player.
    Mike
  2. RichKS
    RichKS
    Apr 25, 2005
    566
    Southampton
    +50
    I had one of the LCD ones and found taht it worked OK. The learning function was rubbish though, but once it HAD learned a function it worked fine.
  3. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,187
    Welwyn, Herts
    +866
    I think that Gemini recognise that the learning function isn't reliable, as you have to hold the old remote very close, stay away from light bulbs, save the new codes only when you've tested them, etc........, but at the price it does make a lot of sense.
