Geforce4 420Go and HDTV
Discussion in 'LCD & LED LCD TVs' started by Ol!ver, Oct 15, 2005.
  1. Ol!ver
    Ol!ver
    Jun 28, 2005
    4,765
    71
    Sheffield
    +98
    've got a laptop with a 420Go chipset, and want to output to my HDTV. Problem is that no 16x9 resolutions are listed. Ive got the latest drivers I can find but it's not playing ball.
    Is there something I can get to force resolutions? The drivers for normal nvidia cards allow it I think, but they wont work with this chipset.
  2. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +26
    Powerstrip is a free app that should help you out, however that 420 may melt if you try and play HDTV. No offense. HDTV Clips (particularly the quicktime ones) require meaty CPU & Graphics card.
  3. Ol!ver
    Ol!ver
    Jun 28, 2005
    4,765
    71
    Sheffield
    +98
    Cant find the setting in powerstrip, but when outputting at 1280x768 the TV reckons it's 1360x768.....
    Most clips are running fine. The odd one has a fit but it's rare.
