I have a radeon 9500 ordered but its out of stock atm so thought i would try and connect my existing card GF3 Ti500 to HS10. So i plugged in the DVI cable and selected computer on HS10 but no joy. Should it be as simple as this or do i need to do set something either on pj or PC
1. Ensure 'computer' selected on HS10 DVI input. 2. Ensure that the display resolution & refresh rate is set to be compatible with the HS10. Try 1024 * 768 @ 60hz. 3. AFAIK the NVIDIA cards will not show 1368 * 768 with the HS10. I had to buy a radeon card. Rgds J
