GeForce Gtx 260 with Hitatchi 32PD5300E
jackwetson
Hi All,
I have a PC with a GeoForce GTX 260 (GeForce GTX 260 | Specifications | GeForce), connected to my Hitatchi 32PD5300E via the AV300 Media Box. I'm currently using S-Video from the card into a scart (which the audio goes into).
To be honest I just cannot get the screen resolution right, and I'm a bit reluctant to spend any more money on cables when I'm not really sure of the best way of setting this up.
Just wondering if anyone had any ideas?
EndlessWaves
So you're getting a picture but it's not right somehow? If it's too small/too big for the screen then you may need to adjust the overscan/underscan settings rather than the resolution.
Looking at the manual for that model it appears to have DVI and VGA inputs which should be a lot simpler to use as it gives a list of accepted resolution for them.
