GeForce 5600 256MB EQ problems
Discussion in 'PC Gaming & Rigs' started by Nitro, Nov 24, 2003.
  1. Nitro
    Nitro
    When i installed my new video card about two months ago until today i have problems with ALL games that i have played so far Unreal Tournament 2003, Unreal 2, Call of Duty, Wolfenstein Enemy Teritorry. When i play those game they get some graphics porblems likethe floor goes black, i on the walls i start to see like graphitis, lots of crazy things, i don't know what to do, i have format my computer yesterday and it continues with the same problem.
    Any help would be aprecciate.
    Thanks Nitro;)
  2. Kramer
    Kramer
    Is your PSU up to the job?
    A possibility.......
  3. Nitro
    Nitro
    PSU?, plz explain if you can.
  4. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    power supply unit mate.
  5. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,951
    38
    Scotland
    +20
    Do you have the latest Pathches for both the games and graphics card?
  6. Nitro
    Nitro
    Yes, last week my brother try his DDR 400 in my PC and he tells me that when he runs the games they don't do any weird graphics error.
  7. InsertNameHere
    InsertNameHere
    Sep 17, 2003
    264
    London
    +3
    I’m not sure I follow…‘DDR 400’ is a type of memory mate and from what you’ve said I’m not entirely sure whose tested what in what. Either way, if you’re having problem with all games, patching them to their latest version won’t make a difference. Just make sure you have:
    - all the right Window’s update (most importantly the latest service pack(s) and DirectX 9.0b)
    - that you’ve tested different Detonator driver’s (there might be a problem with one version)
    - that you’ve got a (decent) 300 watt + power supply.
    Also, if possible, try the card in your brother’s computer and see what happens. That will give you an idea of where the problem lies.
    Hope that helps,
    Alex
  8. Nitro
    Nitro
    I have a 500wtt power supply
    All the windows update
    And i have try some of the ForceWare Drivers
    A firend of my brother have the same motherboard that i have, and the graphics card too, the only thing that we don;t have same is the memory he have 1gb DDR 400, i Have 1gb DDR 333 and is runnig 320 due to the chipset limitation.
    I think that the problem here is the memory
