geforce 2 mx or raedon ?????
Discussion in 'Desktop & Laptop Computers Forum' started by jason t, Jun 3, 2001.
  1. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    hi i want a graphics card for dvd playback .
    i will be using it with a sanyo plv30 can someone pleaserecommend the best card to buy
    thanks
    jason
  2. Spacecat
    Spacecat
    Apr 1, 2001
    3,422
    London
    +1,087
    geforce 2 mx is a superb card for dvd playback and is v stable with WinDvD 2000.
    the radeon is also v good but a bit more flakey with ATI player.
    I use the geforce 2mx with a Tosh MT1 and windvd 2000 and get superb results as well as DD/DTS passthrough capability
  3. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    Hercules 3D Prophet II MX 32MB - RETAIL
    is this a good card for htpc ?
    or is there anything cheaper i can consider?
    thanks
    jason
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The Hercules is a very good card. See if there is a newer GeForce 2 MX 400 version around, this will be faster ans not much more expensive. There may not be because Hercules are moving their cheaper cards over to the PowerVR 3 chipset.
    Rick
  5. Alaric
    Alaric
    Mar 12, 2001
    1,886
    Peterborough, Cambs, UK
    +220
    Hi there,
    The Geforce2 MX suffers badly from RFI filters, the spec's are a bit lax on this so some cards apear to perform better than others. My Innovision Tornado DualHead was apawling, with really fuzzy output on either connector, let alone low bandwidth on the second connector.
    Some people say that this problem also only affects higher resolutions, but i wouldn't say [email protected] was that intensive !
    Mine was so bad, my 8yr old ATI 2meg Mach64 beat its picture quality.
    Swapped it for a Radeon VE, this is much crisper, even before running up a DVD player. True the VE has some custom resolution intricasies (Its posible, but fiddly), but is miles better.
    Cya,
    Lee
