Gears of war Problems
hi i got Gears of war for pc today and i have a pretty decent pc but the frame rate slows down alot
My spec is:
Windows xp media cener 32Bit
windows vista ultimate 32bit
CPU Intel Quad core Q6600 2.40GHZ
GEIL BLACK DRAGON GAMING SERIES DDR2 4 x 1GB 1066mMHZ
Asus P5K Deluxe 775 DDR2 P35 motherboard
nVidia GeForce 8800 ULTRA 768MB GDDR3
is it all patched up?
i have the same cpu and 4gb ram and a 7900gs and it stutters a little at the start of areas etc. but for the most part its not too noticeable.
what drivers you using
I had a dodgy 8800 ultra, check if it stutters in other games, half life 2 loast coast is the best example of this...
what resolution are you playing at, on that system 1680*1050 Max settings DX10 and No AA is the highest i'd push it... should play fine with a few rand slow down scenes...
Razor
Dave2
I played this today on my machine settings as followed
1920x1080 @ 60hzz max settings
core2quad q6600 @2.4ghz
4x 1 gig ddr2 667 mhzz
8800gtx 768mb
I have no problems what so ever well the only problem i have at the moment i cant log into live ... anyone else got this problem ?
Tejstar
I see, I thought it used to say 'Banned' when someone was banned, unless I'm imagining things...
zulu69
Sorry to resurect a dead thread BUT
Put in GOW today to play it once over again (very fun game) and to my complete and ecstatic suprise a new patch has been released (3rd March). The game should prompt you to install it via x-live.
Anyways the new patch COMPLETELY fixed any issues i had (stuttering mainly). Game is now 100% silky smooth 99% (except for the loading etc but not nearly as bad as it was). The game was tops before (most of the time) but now it runs like a dream all the time.
Razor
I thought I would give Gears a few goes online only to be greated with an update I cant install. Every time I go to install the patch it comes up with this:
old file not found. However, a file of the same name was found. No update done since file contents do not match.
Does anyone know how to get round this.
zulu69
Sorry might be a silly question. But have you tried downloading it (from the website at http://gearsofwar.com/GearsPC ) and installing it manually.
ALSO have you got the NoDVD crack? If so i'd recommend that you copy the original exe over.
Otherwise check this thread out. http://gearsforums.epicgames.com/showthread.php?t=604485. Hopefully it will help.
