Gears of War faulty discs
Discussion in 'Xbox Forums' started by liteon, Dec 15, 2006.
  1. liteon
    liteon
    Aug 23, 2001
    95
    HI
    just wanted to ask anynody if they have had problems with gears of war, my disc keeps stoping and saying the disc is dirty. The only thing is this is my second copy of the game as the first had the same problem and the disc is perfectly clean. This is the only game which this happens on as my other games play fine. Just wanted to know if anyone else has had this problem?
    Woz
  2. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,297
    Bristol
    +10,023
    I might be wrong but it sounds like your drive is on its way out because when they start to have trouble reading discs that have nothing wrong with them then it is not a good sign.
  3. Member 55145
    Member 55145
    Jan 18, 2005
    12,082
    +3,483
    yet his other games play fine?
    could be a faulty batch of discs... wouldnt be the first time. i dont buy many games but metroid prime and FFVII for PC were two i remember that had faulty discs
  4. liteon
    liteon
    Aug 23, 2001
    95
    Hi thanks for the reply all my other games play fine, both the gears of war have been the limited edition versions might ask at the shop if they have had any problems.
  5. Ico.
    Ico.
    Jul 4, 2006
    3,293
    Mossley.
    +498
    I had this problem with Oblivion and got Game to change the disc, still had the problem. Then PGR3 did it a few times and eventually Just Cause. Each time it was after around 45 mins to an hour. Eventually I found out the 360 was overheating and causing the problem (it was only 7 weeks old!).
    Took the 360 back to Game for a straight swap with no problems and the new one has been working fine.:rolleyes:
  6. redmarkred
    redmarkred
    Jan 25, 2006
    1,239
    +88
    That's how the trouble with my 360 started. Got read errors with Oblivion but no other games. Then eventually it started to happen on other games :(
  7. liteon
    liteon
    Aug 23, 2001
    95
    Oh dear hope it doesnt start doing it on other games then, I have had the machine since launch day so stuffed if it goes faulty. Thanks for the replies.
  8. liteon
    liteon
    Aug 23, 2001
    95
    Forgot to ask Ico when you say yours was over heating did the console feel warm on the outside aswell, as mine feels cool and the case doesnt get warm.
  9. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,297
    Bristol
    +10,023
    Might want to think about taking out the extended warranty, just incase it does die in the next few months.
  10. Ico.
    Ico.
    Jul 4, 2006
    3,293
    Mossley.
    +498
    Yeah the case was a little warm, and the discs did get quite hot!
    Hope you get it sorted.:)
  11. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    I *don't think* you can do it once it's out of it's original 12 month warranty...
  12. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,297
    Bristol
    +10,023
    Apparently according to MS the original 1 year warranty doesnt end until the end of December so you still have a chance.
  13. mjw123
    mjw123
    Apr 21, 2004
    1,302
    48
    +32
    Have experienced this same problem about 6 times since getting the game !
  14. liteon
    liteon
    Aug 23, 2001
    95
    will look into the extended warranty, but I think its as azzin said dont think you cant do it once it is out its original warranty.
    Many Thanks for the advice, might hire one from block buster to see if it is a faulty batch of discs.
  15. liteon
    liteon
    Aug 23, 2001
    95
    Thanks indiana jones will look into that, mjw123 if you have had the same problem I might contact the game company and see what they say will let you know if I get a reply.
  16. liteon
    liteon
    Aug 23, 2001
    95
    Just thought I would let you all know I have just looked on epics website which you can then go to the gears of war forum. There are alot of people complaining about the clean your disc errors and problems with the game freezing while playing. Doesnt seem to be any reply from epic about it though. People on the forum reckon it could either be software glitches with the game or cheap discs that have been used as people are having the same problems with brand new consoles, at least my machine might not be on the way out!!. If i find anything else out I will let you know.
  17. rEVILospud
    rEVILospud
    May 1, 2005
    2,295
    Shoreham-by-Sea
    +235
    I got the 'clean the disc' message a couple of times last week. Once in Single Player and once in Co-op (in completely different parts of the Game). I looked at the disc and it seemed to have the most tiny circular scratch; I took it back to Game, got it replaced and it seems to be running fine so far. My machine btw was replaced by Game only a week ago, so hopefully thats not the issue at all.
    They're getting to love me, coming in every other day moaning about something :)
  18. kasumi
    kasumi
    Sep 22, 2004
    872
    wigan
    +33
    I've noticed my gears of war disc having difficulty reading while in game as it slows & stutters the play occasionally.
    None of my other 7 games do this.
    I've said it before and I'll say it again, the 360's dvd drives are a piece of sh!te.
  19. BFassassin
    BFassassin
    Sep 27, 2006
    294
    +10
    I am getting a lot of disk read errors as well. Its really annoying. I hope they can do something about it
  20. TEVEZ032
    TEVEZ032
    Jan 16, 2006
    2,037
    +95
    i had loads of disc read errors on PES6; swapped the disc in GAME and had none since... :D
    g
  21. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    the original gears of war disc i got,when i phoned to exchange it,i tested it,and it did not lay flat on the unit,almost like it was bent,like the edges of a plate..warped even..took it back and got another,and thats been fine.
  22. bignige
    bignige
    May 13, 2003
    718
    +32
    It's not your drive, it's the discs. Lots of people are reporting the same disc error.
  23. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,915
    +4,460
    I've had this error a few times, right at the start of the game. Am nearly at the end now and haven't had anything recently. Every other game I play is fine. My 360 doesn't get in the least bit warm and the discs are never hot, even after extended gameplay sessions.
    I also have a mate who just got a 360 and the first game he played, with the 360 just out of the box, was GOW...and he got the same error.
    I dont think it's the console myself...I think it's something to do with the game and/or the disc.
  24. rEVILospud
    rEVILospud
    May 1, 2005
    2,295
    Shoreham-by-Sea
    +235
    Got the 'clean disc' message last night on my new copy of the game. It has only happened this once, but worrying nonetheless.
  25. DC
    DC
    Mar 4, 2001
    156
    UK
    +10
    This happened to my standard Gears of War disc. Took it back to Gamestation and got my money back as all they had in stock was the limited edition copy. Seems funny that the same Gamestation is only selling the Limited edition due to lack of stock and has done for the last few weeks!
    Anyway bought another copy from elsewhere and touch wood all has been fine.
  26. crocket99r
    crocket99r
    Oct 18, 2006
    101
    16
    Just thought I'd add that I got my (standard) copy around 4 days before it was meant to be released, don't know why, and (touch wood), never had any problems so far.
  27. steve tyler
    steve tyler
    Jul 14, 2000
    268
    Chigwell,Essex
    +15
    Hi mate,yeah I get that exact same error but it only happens now and then,and it`s only on gears and no other games.Strange.I did get the ring of death (3 lights) about 3 weeks ago but touch wood everything has been fine since.
  28. liteon
    liteon
    Aug 23, 2001
    95
    strange thing is I am now on the last act of the game and it has not been doing it, so I replayed one of the earlier acts and it started doing it again. So maybe its only on the early stages of the game.
    Have a good xmas everyone
  29. KSK MAfio
    KSK MAfio
    Dec 26, 2005
    132
    Milan
    +6
    I got the error message today at the last level... I have finished the game once already without any problems. Now is working fine (sometimes gets a little bit slow….
    I hope is not the 360.
    PS: I got the limited edition
  30. Scen3
    Scen3
    Aug 5, 2006
    158
    Glasgow
    +5
    I have just started having this problem too, my xbox360 is only 2 weeks old. I've already completed gears of war and it was running smoothly however when i played it all over again in hardcore mode @ campaign.. it keeps freezing at the bit after you kill the beserker in that greenhouse. Xbox was running for a bit and the disc was hot so will wait in the morning if i still get it. everything else was fine like playin live and so on.. plus i dont play that much.. about an hour or two. then switch then after 5 hours or so.. i'll probably play again for 1 - 2 hours. dont understand this.. MS SUCK HARD. seriously.. couldnt they have atleast built decent working systems.. i never had any problems with my psone and ps2 (which I've had over 5 years).. I opted to go for MS this time because it was alot more cheaper than ps3. I mean you can talk about whos better or cheaper or w/e. At end of the day i want a decent console that is reliable and durable not to start having problems after 2 weeks!!!!!!!!!!
