GE imager 910E
Discussion in 'Projectors, Screens & Video Processors' started by helipilot, Sep 29, 2001.
  1. helipilot
    helipilot
    Sep 20, 2001
    314
    Hamilton
    +19
    Does anyone know where I can get technical specifications for a GE Imager 910E CRT projector.
    I have found very little information on the net.
    So far I have discovered it might actually be a 901E and that it may have been manufactured by Zenith. I think there may also be an equivalent NEC model.
    Also any opinions to its age, value and image quality ?
    <br />---------------------
    <br />Alan
  2. Gordon @ Convergent AV
    Jul 13, 2000
    13,981
    +2,785
    Alan,
    Unless I'm mistaken it's a NEC9PG in disguise. The same as the unit sitting at StereoStereo just now. If this is the case it's a great, great 7"/7.5" CRT projector.
    Gordon
  3. larsan
    larsan
    Specs,
    GE Imager 901E<br />Horizontal scan rate 15-60KHz<br />Vertical scan rate 38-150Hz<br />Quad Standard Decoder/S-Video/RGBHV
    The closest NEC model is the 6PG
    /david
  4. helipilot
    helipilot
    Sep 20, 2001
    314
    Hamilton
    +19
    I now have an installation/service manual for the projector (thanks Neil).
    Spec: GE Imager 901E
    Horizontal 15 to 90 KHz
    Vertical 38 to 100 Hz
    1000 TV lines, 70 MHz bandwidth
    It is a 9PG after all ! some pages in the manual are even marked 9PG rather than Imager 901E ! The specs metioned by David above are indeed a closer match for the 601E (NEC 6PG).
    Alan
  5. larsan
    larsan
    Sorry Alan.
    My source must have got it backwards... :rolleyes:
    Sorry...
    /David
