Quantcast
Gateway Plasma's
E
EdwardDAL
Does anyone know anything about Gateway plasma screens? I am interested in the Gateway 42" Ultrabright Plasma.
Thanks for your help
buns
if im not mistaken, there was a big blowout of gateway machines in the states recently..... the questions asked on avs make me think that the only reason to buy a gateway would be if it were ridiculously cheap.....
ad
E
EdwardDAL
£700 ?
What is the picture like? It has EDTV, but is there really a difference between normal tv and EDTV?
StooMonster
If it's a US plasma, it's internal frame buffer may only be set to 60Hz and could judder when displaying PAL television or Region2 DVDs.
StooMonster
E
EdwardDAL
StooMonster
Would a PAL to NTSC converter work? As I think it is the US version, or would it be better to convert PAL to a computer signal and then into the plasma?
StooMonster
Originally posted by Jasonjo
Youve gone judder mad Mr S. :p :D
Well I did get an Aknoledgement in the DVDO iScan HD manual for my judder test idea. :D
StooMonster
Similar threads
