Garmin Street Pilot i3 HELP PLEASE!
R
rainbowsend
not sure what's gone wrong with my sat nav but whenever I turn it on, wherever I am, it shows I'm starting my journey in Horse Guards Road in London & I'm hundreds of miles from there & have never set it to go there. I'm confused. I don't use it all the time but had it working correctly a few weeks back with no problems. Can I also ask under 'settings' & then GPS mode I can choose 'normal', 'gps off' or 'waas/egnos'. which should I be using (sorry a little thick with this sort of thing). if anyone could throw any light on what has happened with my navigation setting then I'd love to hear from you. :lease: thank you
Chris Muriel
That might be the default "home location" if it's somehow lost its memory or reset itself.
Try setting your home location on it - suggest you do not use your full home address in case it gets stolen from your vehicle whilst you're not home. Use somewhere nearby though.
Chris Muriel, Manchester
R
rainbowsend
thank you for trying to help me but I've now tried that, re-setting my (near!) home location but its now showing my journey is starting at Pall Mall, London! I guess I will have to get it checked out somewhere but how much it would cost I wouldn't have a clue & bearing in mind they are are now so reasonable it would probably be best to ditch it & get a new one. thanks for taking the time to reply, I appreciated that.
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
