Garmin, Peugeots etc
4
46049
Garmin SAT NAV with built in RDS - anybody got one of these ?
Seems a better solution than TT with no extra cables ?
Also I've got a Peugeot which I'm told has a different type of windsceen which SAT NAV might not work with ?
any help gratefully rec'd
Mr Claypole
I have a Garmin Nuvi 310 which works fine in my '02 Peugeot 307 so I guess your chosen model of Sat Nav will work too.
I had also heard that Peugeot asthermic windscreens would block the signals but thought I would try it first before buying an external aerial!
Hope that helps
