varunswati
- Joined
- Mar 29, 2008
- Messages
- 6
- Reaction score
- 0
- Points
- 2
The problem has been resolved... I received the help files from Garmin support and they work perfectly...
Old Msg:
I noticed that if I go to he help menu and click on any help item, it just beeps but does nothing- as if the help file could not be found.
I checked in the Garmin folder, but there is NO help folder.
I suspect I might have moved it to the SD card and eventually deleted it?
Can anyone advise how I can get the help files.
I have already tried the web-updater and the firmware is current at version 5.
Thanks for all your help in advance,
Best Regard,
Varun
Old Msg:
Best Regard,
Varun
