Garden Room
Discussion in 'Home Cinema Buying & Building' started by malguru, Feb 18, 2014.
  1. malguru
    malguru
    Mar 21, 2011
    Troon
    Currently working on a garden room.
    Following specs.
    Raised 1 foot from ground. this room is 6 meters by 4 meters.
    Cedar clad.
    7 foot height inside.
    Using ceiling speakers Sonance Visual performance VP65R 6.5" round speaker
    with a
    Sonance Cinema Series SUB10-250-RET 10" Square Subfooter
    and the following AV amp.
    RX-V3067 - AV Receivers/Amplifiers - Yamaha - UK and Ireland
    The walls will be 12mm plaster board..
    Issues i would like to clarify are the following:
    1, when i cut the holes for the speakers what to use behind them to insulate/soundproof
    the building will be lined with 100mm kingspan.
    2, sub placement, the system will be 7.1 THX dictated the sub placement to be front centre, there is enough room under the fixed screen. Really just want to get this as good as I can first time round.
    Any other observations definitely appreciated.
    Any recommendations for exact speaker placement and further reading?
    Thanks!!!
    M
