Question Garage conversion
Discussion in 'Home Cinema Buying & Building' started by Davidcozier, Jun 12, 2018.
  1. Davidcozier
    Davidcozier
    Jun 9, 2018
    10
    Coventry
    Does anyone have recommendations for a garage conversion specialist for you single garage.
    Trying to get some quotes together to get started asap.
    Coventry area
    David
  2. Atomicus
    Atomicus
    May 10, 2009
    583
    46
    Chichester
    +144
    If you are planning on sound insulating the space, you might have your work cut out for you finding a builder who understands the methodology and concepts that go in to this. I discovered this myself, with most absolutely clueless and dumbfounded when I started talking about a room within a room, decoupling, sound insulated plasterboard etc.
    You may be best served determining the correct techniques to employ, and then instructing someone to do it... assuming you aren't comfortable with going about that yourself. It's not rocket science, and any builder can surely get their head around it, but they just need to be told exactly what to do.
    You could look at specialist home cinema building companies, but that will be expensive.
