garage conversion or not?
Discussion in 'Home Cinema Building DIY' started by fish, Feb 24, 2003.
  1. fish
    fish
    looking to turn garage into h/t-hi-fi room.Size will be 15x8ft when complete,is there anybody who has already done this conversion and found problems with size.Or have you wished you went bigger.ps rooster NICE CONVERSION.
  2. voodooflux
    voodooflux
    Nov 2, 2002
    265
    Redditch, UK
    +12
    Hi fish
    Those dimensions are almost exactly the same as my garage. I'm just underway with the conversion, and I'm pretty sure that the size will be fine. A couple of times I've sat on the sofa in the cold, empty garage and tried hard to imagine what it will be like. Bit sad, really :rolleyes:
    It might be a good idea to "mock up" the stuff that will be in there (like using a sheet or something to mimic any walls you need to build) and that should give you a (very general) idea. Get some chairs in there to, so you have an idea of the desired seating position.
    v.f.
  3. fish
    fish
    v.f cheers for that.Will try that later.Just worried that my speakers(mission 752) & rel(150)would be a bit OTT in such a small space.But what the hell.
  4. Tonto
    Tonto
    Feb 6, 2003
    90
    11
    Harrogate, England
    Fish,
    Rooster has done the garage conversion thing .
    http://www.btinternet.com/~anthonyreilly/
    (Rooster, hope you don't mind me mentioning this).
    Arrrgh !,,, just re-read the end of the first post !!!!!!!
  5. rooster
    rooster
    Mar 18, 2002
    216
    Edinburgh
    fish my room is 8.5ft by 17.5ft and although i could have made use of more space it is more than adequate. One thing i wanted that i ended up doing without was a 3 seater reclining sofa but decided it would just overpower the room. ....Go for it.
  6. fish
    fish
    well rooster. Thats good to know, I will go ahead and get some building quotes,(brickwork only). Had sofa in there myself today,looks that your right.2 seater it is KEEP YOU POSTED FISH.
  7. OBI-1
    OBI-1
    Fish / Rooster -
    My garage is also 8' x 15' approx. Once all the dry lining and boxing in of meters / fuse board etc has been done, I will end up with about 8' x 12 1/2'.
    still waiting for quotes from southern electric to move the 240v service cable so I can cut in the new doorway from the house to the garage. Also STILL waiting for quotes from builders and electricians.
    With any luck work might start by Christmas!!! ( and they wonder why tradesmen get a bad name )
    OBI-1 out.....:mad:
  8. mr ooops
    mr ooops
    Mar 4, 2003
    3,592
    103
    Hardwicke and Wotton
    +353
    rooster do u mind if i ask how much such a conversion cost?
    cheers
    fraggy
  9. rooster
    rooster
    Mar 18, 2002
    216
    Edinburgh
    Costs for building work was £2500 which included
    Joiners Fee
    Electricians Fee
    Plasterers Fee
    Plumbers Fee
    Flooring, plasterboard, insulation, switches, and all other materials. So not too bad.
    However and this is where you could save, I spent
    Projector £2150
    Lights £100
    Programmable Dimmer £180 (Allows up to 20 "scenes" to be selected at touch of a button)
    Carpet £250
    Tables £350
    Chairs £225
    Prog Scan DVD player £150
    Cables £150
    So all in roughly £6k. Was it worth it? You bet it was. Watching movies on the big screen at home is awesome.
    Got a very funky electric screen for nothing off my wifes uncle So that was a bonus
  10. cookiemonster
    cookiemonster
    My current listening room (not garage) is exactly 15"x8" and works very well, using B&W standmounts and Mission sub. A couple of extra feet in width would have been preferable for greater speaker seperation, but that is only a minor quibble.
    Don't recommend a 3-seater though :nono: , otherwise u will be climbing over it to get on it.
  11. fish
    fish
    cheers cookiemonster.Looking now to extend garage by 2ft(wide) subject to permission etc,and cost.otherwise size stops as it is. cheeers fish
