thedude
Hi guys, I'm doing a garage conversion mostly myself.
Now I have a gap between my breeze blocks and window which will be on the outer bricks. This is about 75mm to 100mm as we've been using thick insulation.
My question would the window would get drilled into the wall on the side how do I bridge that gap? Do I need to use cavity closure's? Will they be storng enough for a window sill on them?
Thoughts and answers if possible
