gapless playback on nwhd5h
Discussion in 'Headphones, Earphones & Portable Music' started by dq1967, Aug 14, 2005.
  1. dq1967
    dq1967
    Mar 14, 2004
    30
    Where do we set the flag or whatever for gapless playback, is it on the machine or in Sonicstage. Haven't actaully got machine yet, but I'm ripping CD's to PC in antcipation.
    thanx
    dq
  2. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,551
    England, UK.
    +554
    Assuming you are ripping the CD's into ATRAC format then you do not need to flag anything as gapless playback is a feature within the encoding of the format.
  3. dq1967
    dq1967
    Mar 14, 2004
    30
    so that means it simply duplicates what's on the CD ?
    sorry for being a bit thick
  4. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,551
    England, UK.
    +554
    Yes - so for example if you have a dance music CD that is a DJ mixed set with several tracks running into each other this will play with no "gap" between the tracks.
    And no need to apologise, everybody gotta learn sometime.
  5. shadowritten
    shadowritten
    Keanos, does gapless work on ATRAC3 as well as ATRAC3Plus? Never tried, but when I 'test purchased' X&Y from Connect, there was a definite gap between 'White Shadows' and 'Fix You' (normally seamless) at ATRAC3 132.
  6. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Yes, ATRAC3 plays gapless as well.
  7. shadowritten
    shadowritten
    Wonder why it didn't work from Connect then? Weird ...
