Gap between tracks on mixed album
Discussion in 'Desktop & Laptop Computers Forum' started by Jon, Mar 15, 2005.
  1. Jon
    Jon
    I have recently sorted out my CD collection and started transfering it to my PC. I am using exact Audio Copy to rip the music, I am them compressing it using Monkeys Audio and playing it through Win amp. The problem is that on mixed albums i get a short gap between the tracks, does anyone know how i can remedy this? Its only a very short gap, less than a second but its very annoying!!!
    jon
  2. stlic
    stlic
    Feb 17, 2004
    769
    +19
    You can use EAC to create a MP3 image + CUE sheet that will give a continuous play.
  3. SimonInd
    SimonInd
    May 9, 2001
    209
    London
    You should be able to use a gapless plugin for WinAmp that will remedy this. If your soundcard supports ASIO its an option in the ASIO output plugin. Otherwise have a hunt around the WinAmp plugin zone.
    Simon
  4. Razor
    Razor
    Dec 15, 2004
    37,727
    2
    +12,503
    Jet audio lets you rip a cd with the option of a gap or contineous play. Good little program.
  5. Jon
    Jon
    Thanks for your help everyone! I have now sorted the problem, i needed to change a setting in winamp and it works fine now! Thanks again!
    Jon
