Gaming with the LE26R41BDX
Discussion in 'LCD & LED LCD TVs Forum' started by sarkster, Jul 15, 2005.
Tags:
  1. sarkster
    sarkster
    Dec 1, 2004
    41
    Im having a problem connecting my gamecube to my new lcd as above. The panel doesnt seem to register that a VGA cable is connected, but the tv cant be at fault as my laptop connects to the set no problems. Anyone else experienced (and fixed) this problem at all?
    Sark
  2. andrewfee
    andrewfee
    Apr 27, 2004
    3,061
    +500
    What are you using to hook up your Gamecube over VGA? There's no official VGA cable for the cube, so you must be using some kind of VGA box.
    The easiest way to solve this is probably to use component cables.
