meizumintyboi
Established Member
- Joined
- Aug 28, 2007
- Messages
- 245
- Reaction score
- 7
- Points
- 48
lol i just started testing with orthos just before reading your posts
with the stock cooler @ 3GHz speedfan was reading temps of 66c+ when running orthos
so instead i reverted all voltages back to stock, but my 800 was running at 900MHz, so eventually the ram overheated, but orthos and my cpu alarm alerted me before any damage could be made.
so now again i have reverted all voltages back to stock, with x10 FSB multiplier at 2.5GHz & memory at 800MHz
now idles @ 39c-42c a bit lower than what it was. averages at about 59c under full load, which is about right, maxes at 62c, allot lower than previously, still above 60c tho, but that's fine because even Crysis & WiC doesn't use 100% cpu like orthos right, because when i switch between cysis & speedfan, the reading is not as high as 62c on both cores
well got my arctic cooler 7 pro coming in, that should resolve the issue, right?
and does anyone know how reliable speedfan readings are?
