Gaming PC £600 - £850
Discussion in 'Home Entertainment Computers' started by weavesno1, Jul 29, 2012.
  1. weavesno1
    weavesno1
    Apr 14, 2011
    2,079
    116
    Eccleston Lancs
    +1,968
    Hi guys, I'm looking into getting a decent gaming PC and since it's been a good few years since my last PC I'm a little concerned over the ability to run the most demanding games. I'm interested in FPS games and driving games. I want to be able to run games like ARMA 2 as well and the Day-z mod.
    Will a budget of between £600 and £850 get me what I need. This is my budget for the tower it self not a monitor.
    I'm hearing all sorts about graphics cards formations such as crossfire and SLI (baffled)
    Do I need 4gb, 8gb or 16gb of ram
    What's the best graphics card Radeon or GeForce?
    And which online pc builders would you recommend?
    I also want to be able to run today's games at maximum detail, is this possible with this sort of budget.
    Cheers guys
    Ps could you recommend your own systems with a brief breakdown of the contents
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,942
    Norfolk
    +2,549
    Generally they're for high end stuff, unlikely to be worthwhile for an all-new system on your budget.
    8GB is generally the most sensible choice at the moment.
    Depends on how much you end up spending on the card but at the sort of prices you're probably looking at(~£200) they're both competitive
    It depends on the resolution, but if it's medium to low (1920x1200 or below) then for most games definitely, a few do have one or two options designed for really high end cards but you could still max all of the sensible options on them.
  3. weavesno1
    weavesno1
    Apr 14, 2011
    2,079
    116
    Eccleston Lancs
    +1,968
    Cheers mate could you look at this spec for me also:
    Main Specification:
    • AMD 8-Core FX-8120, 3.10Ghz Processor
    • 16GB of Corsair Vengeance 1600Mhz DDR3 Memory
    • 2000GB (2TB) Hard Drive Storage
    • XFX AMD Radeon HD 7950 3GB GDDR5 Graphics Card
    • Asus M5A78L-M/USB3 High Specification Motherboard
    • LG DVD Re-Writer Drive
    • Cooler Master HAF Case
    • OCZ ZS Series 750W 80+ Bronze Active PFC PSU
    • 2 Year RTB Warranty
    This is £845
