Gaming on LCD's at close range?
Discussion in 'LCD & LED LCD TVs' started by Batch, Oct 3, 2005.
  1. Batch
    Batch
    Sep 27, 2005
    2,695
    83
    University: Lancaster, Home: Cambridgeshire
    +200
    I have heard that when gaming on LCD's at a close range. Individual pixels can be seen! Is this true?
    Batch
  2. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    guess that would have to depend on both the set and the game??? :confused:
    and how close
  3. Random Hajile
    Random Hajile
    Jul 1, 2004
    551
    Nottingham
    +22
    depends how big the screen is. I have a 26inch screen and can`t see individual pixels when upclose. But If i had a 40inch screen and sat right In front of it i would :D
  4. Batch
    Batch
    Sep 27, 2005
    2,695
    83
    +200
    20" TV - sitting *measures* 80 cm away from screen. Would i see individual pixels?
  5. andrewfee
    andrewfee
    Apr 27, 2004
    3,061
    +500
    Well it's recommended to sit 2x the diagonal for HD material (next-gen consoles) and 3x for SD/ED material (current consoles, tv etc) but that should be fine.
    I wouldn't worry about it at all.
  6. manzee
    manzee
    May 25, 2005
    25
    You can see the pixels, especially on current gen stuff as 99% is 480i or 480p. But do you care?
    If you sit close to a CRT, you can see the scanlines! Oh TEH NOES!
  7. Batch
    Batch
    Sep 27, 2005
    2,695
    83
    +200
    How obvious are the pixels, do you specifically have to stare to see them?
