gaming mini pc help
Discussion in 'PC Gaming & Rigs' started by reece123, Feb 18, 2013.
  1. reece123
    reece123
    Feb 18, 2013
    3
    hello,
    im looking to build a mini gaming pc, need a space saver and future proof.
    below are components i want to use - max is £600
    all help appreciated - is everything compatible and good to build?
    SILENT Pure Power L8-CM-530W - Power supply
    COOLER Master Elite 120 Advanced Cooler (RC-120A-KKN1)
    ASUS P8Z77-I DELUXE - 1155 Socket - Z77 Chipset - Mini-ITX
    INTEL Core i5 Ivy Bridge 3550 - 3.3 GHz - Cache L3 6 MB - Socket LGA 1155 (BX80637I53550)
    ASUS GeForce GTX 660 DirectCU II - 2 GB GDDR5 - PCI-Express 3.0 (GTX660-DC2-2GD5)
    KINGSTON HyperX Predator PC Memory 2 x 4 GB DDR3-2400 PC3-19200 (KHX24C11T2K2/8X)
    SANDISK EXTREME - SOLID STATE DRIVE - 120 GB
    I ALSO WANT IT TO BE SILENT SO ANYTHING TO ADD ON TO DO THIS?
    :lease:
  2. razer1
    razer1
    Jan 5, 2011
    923
    46
    Leicester
    +162
    I would perhaps suggest if budget allows to switch to I5 3570K as will allow more options for overclocking to get more out of the system.
    Also a bigger SSD - 240gb would give you more game data storage as you dont have a normal drive. (120 is not much when windows takes up 40odd gb when sp's installed ( Mines nearly full and I just have apps on it !! most is purely service packs.)
    Case? unless ive missed it, you aint got one......:facepalm:
    Ryan
  3. DavidT
    DavidT
    Oct 30, 2001
    2,488
    +257
    I think you will struggle to get a silent gaming PC. There isn't much you can do about the GPU and PSU fans but something like a Scythe Shuriken CPU cooler will help along with good quality case fans like Noctua's.
    David
  4. reece123
    reece123
    Feb 18, 2013
    3
    THIS IS THE CASE:
  5. reece123
    reece123
    Feb 18, 2013
    3
    is everything compatible?
  6. paulktreg
    paulktreg
    Feb 27, 2011
    940
    46
    Clitheroe
    +131
    IT SAYS "Advanced Cooler"! :p
  7. razer1
    razer1
    Jan 5, 2011
    923
    46
    Leicester
    +162
    Lol sorry! Been a long day and didnt spot that! Tbh, I thought you had put a 3rd party CPU heatsink cooler tbh!
    :facepalm:
    I would also suggest getting a large heatsink - something like Arctic cooling pro freezer 8 would work - Pretty silent and as David says, you aint gonna get a completely silent gaming rig.
    You would get a quiet rig with large, small RPM fans but not silent espec when gaming and the CPU and GPU is running at full wack getting frame rates out.
