Question gaming laptop advice
drhcnip
Joined
Feb 23, 2010
Messages
6,114
Reaction score
2,040
Points
1,699
a friend is after a gaming laptop for xmas and has asked for advice
i'm more of a console gamer, though managed to choose a decent gaming pc rig for my daughter, but i want to make sure they get the best they can for their budget
probably looking at a 500-700 price range and from a 'known' seller
would this be capable of running stuff decently? if not, any advice of the sort of spec to look for? cheers
http://www.amazon.co.uk/MSI-Graphic...qid=1447868495&sr=1-32&keywords=gaming+laptop
— As an Amazon Associate, AVForums earns from qualifying purchases —
What stuff are you planning to play on it? The latest games or older titles?
not planning on anything myself...its a 14 year old lad, not been told what he's planning on playing..
had a bit of advice elsewhere and given them three options ranging from the above 940m one to one that has a 970m which is apparently a bit better?
That would be OK:
http://www.amazon.co.uk/Gigabyte-P1...1_1?s=computers&ie=UTF8&qid=1447924523&sr=1-1
It will play most recent games on Medium settings at lower resolutions.
Where did you find a 970m for under 700? and a bit better is an understatement, there is a massive difference between a 940m and a 970m.
The 940m will struggle to play any recent games above low settings and lowest resolution. A 970m will give you 60FPS gaming at 1080P on medium/high settings. It is like the difference between a PS3 and PS4, probably more.
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
