Gamexpert Cooler King
Discussion in 'Xbox Forums' started by hildener, Dec 30, 2006.
  1. hildener
    hildener
    Nov 18, 2006
    95
    +9
    purchased one of these units fans work fine but when using component can only get 480P as even though the output switch is set per instructions the dashboard keeps reporting that output is set to tv not hd. anyone got one of these units and had the same problem.
  2. bagatanmd
    bagatanmd
    Oct 8, 2005
    1,486
    48
    +94
    you got their first model. try calling pinpoint electronics directly so that they can send you a replacement model that can do hd signal via component. they are very helpful with this regard. the updated model also ha s a slot for the wireless connentor for the console. just ask them to send the item first before returning yours to them. thats what i did with mine. now very happy with it.
  3. hildener
    hildener
    Nov 18, 2006
    95
    +9
    thanks very helpful indeed do you happen to have the number for pinpoint electronics.
  4. bagatanmd
    bagatanmd
    Oct 8, 2005
    1,486
    48
    +94
    pinpoint consumer electronics
    mereidian house
    road one
    winsford CW7 3QG
    tel.: 01606 558 428
    fax.: 01606 559 612
