Gamecube, US or UK?
Discussion in 'General Video Gaming Chat' started by jian, Apr 9, 2003.
  1. jian
    jian
    Aug 31, 2001
    2,508
    68
    +77
    Thinking of buying a GC but not sure whether i should go for the UK or US version. As I understand it, the US version plays at a faster frame rate and in full screen, is that true?
    Also, what are the bestt prices at the moment?
    Cheers!
  2. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    Goblin direct have 50 US platinum cubes for £99 each.
    remember US cubes do prog scan as well where UK ones do not
  3. jian
    jian
    Aug 31, 2001
    2,508
    68
    +77
    Thanks!
    Any other advantages apart from that, i dont have a progressive scan tv.
    Cheers.
  4. 2manyconsoles
    2manyconsoles
    Aug 21, 2002
    142
    16
    Chester
    Assuming freeloader gets sorted out I would go for a PAL one - RGB is easier to get and you won't need to shell out for a step down - games should all be 60Hz on it.
    Also with the PAL ones you can get £30 off - people are giving the vouchers that came with the SP away free (I just got one) so you can get a platinum PAL cube (comes out start of may) with Zelda for £99.99 - grab an RGB scart cable, memory card and freeloader and your all set.
  5. RL123
    RL123
    Nov 4, 2002
    1,037
    38
    +4
    PAL GC games are all full-screen, 60Hz or fully-optimized 50Hz. You won't need to worry about poor conversions IMO. The benefit of NTSC games in this generation is mainly release schedules - PAL gets games MUCH later than the NTSC territories.
    If this wouldn't bother you (and as you don't have prog-scan capabilities) then I suggest a PAL Cube. They're cheaper, RGB, and you could always buy a Freeloader if you want the odd US/JAP game (which is what I've done).
  6. Ono
    Ono
    Oct 18, 2000
    1,415
    London
    +103
    Get a modded USA/Jap one.
  7. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    I have a USA/Jap Cube, but since you don't have a progressive scan TV (and since Freeloader finally made it) I'd suggest you go for the PAL one.
  8. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    I've never owned a PAL console and I could never bring myself to buy PAL........but then I'm too set in my ways regarding imports.
  9. Erpland
    Erpland
    If you have a computer monitor you'll get progressive scan on that using a US Gamecube and a modified cable.
  10. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    I'd get a JAP/US switchable one, or buy a JAP or US one and get
    Saurian to mod it.
    the biggest advatage is not getting screwed either by Nintendo Europe or by the retailers for games. I buy loads via dvdboxoffice at around 25 quid inc shipping. Also remember coming soon:
    F-Zero:GC !
    Regards,
    Neil.
  11. jian
    jian
    Aug 31, 2001
    2,508
    68
    +77
    Thanks for all of the replies guys!
    I intend to use the machine on either my 28" widescreen, or if progressive scan is really worth it, on my 17" TFT. How much does the modified cable cost and where can i get one from?
    Apart from that, I'm still not too sure on which to get so I guess it would have to come down on price, don't suppose anyone knows where the cheapest place is, do they? Or has a spare voucher lying around?
    Cheers!
  12. James45
    James45
    Sep 21, 2002
    2,844
    59
    I'd have to say that the size advantage of the tv far outweighs the improved picture benefits of prog scan. Get a UK cube, official RGB scart and a copy of freeloader v1.06b, although you may want to wait for the Platinum coloured cubes to be released in the uk!
  13. jian
    jian
    Aug 31, 2001
    2,508
    68
    +77
    Thanks!
    So what so special about these platinum cubes then? Is it just the colour scheme?
  14. James45
    James45
    Sep 21, 2002
    2,844
    59
  15. jian
    jian
    Aug 31, 2001
    2,508
    68
    +77
    Sure do!
