GameCube S-Video ?????
Discussion in 'General Video Gaming Chat' started by IanW, May 13, 2002.
  1. IanW
    IanW
    Feb 28, 2001
    1,619
    Wiltshire
    +152
    I just bought a GC on Saturday, and was very miffed to find the the old S-Video lead that I had for my N64 does not seem to work on the GC. The adapter into the box is the same but I get no picture or sound!!!!!!!!
    Anyone know whether this should work or not?
    Ian.
    Oh and by the way what is the Digital AV socket for?? Even the Instruciton manual says nothing about it! :confused:
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    I might be right in saying that the GC doesn't do S-Video, but only composite and RGB.
    I'm sure there have been other posts on here about the digital socket, but if not you can always pop over to the forums at www.final-level.com - great gaming chat over there :)
  3. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    You are right - no S-Video on GC.
    I believe the Digital Out is for Component Output for HDTV's etc.
  4. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    It's true, Nintendo decided to disable S-video for PAL gamecubes.
    The digital out on PAL machines is just for interlaced mode with component cables.
    Progressive scan has been disabled by Nintendo for PAL Gamecubes. Oh goody...
    Nintendo decided to re-wire the GC multi-AV output for PAL gamecubes. US cables won't work. At the moment, only official Nintendo Scarts will give RGB, 3rd party ones can only give composite. It's all a bit cack.
