Gamecube - PS2 Video.....
Discussion in 'Playstation Forums' started by Desticado, May 31, 2002.
  1. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    Canterbury, Kent, UK
    +6
    I've run out of video inputs on my tosh 36zp and so im going to use the video switching on my Denon 3802 to handle my games consoles.
    Can anyone advise me on the cables to use for these?
    Can you buy component leads for the ps2 or should I stick to S-video.
    I understand the cube doesnt support s-video so I guess I need to stick with composite for that.
    Any tips greatly appreciated.
    Regards
  2. zcaps57
    zcaps57
    component video is a way to go.
    PS2 and GameCube both have component video cables.
  3. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,498
    Chesterfield town of the crooked (Spire)
    +72
    I had the same problem mate and it appears I have a very similar setup to you.
    I would stick with s-video for your ps2 but component cables are available if you wish to use them
    I have my GC connected via component.
    The cable you need is not available in the uk so here is a link where you can get it from
    http://www.lik-sang.com/catalog/product_info.php?category=0&products_id=1468&
    I ordered mine and it came within 2 weeks
    The cable only carries video and plugs into the digital out on the GC so you will also have to have the cable you are using now pluged into the av out but only using L+R audio.
    The picture you will get looks stunning on the ZP18 I know this because I have got one
    Happy Gaming
