GameCube Freeloader Disc
BIONIC MAN
Any Region Gaming for the Uk Cube
I see that Play.com has it down for 30/08/02 release for the
price of £16.99 ,
Will it work for all NTSC games USA & JAPAN ? ? , Lets hope so
:D
We Can Rebuild Him ( Yeh for Six MIllion Dollers )
N
NeoBlade
The release date for this thing keeps getting pushed back... Anyways yes it will allow for true import gaming however I do know know if it will enable prog.scan using an NTSC game on a PAL Gamecube. If it outputs a true NTSC signal on a PAL Gamecube then it could be interesting indeed since there would be no need for an import GC.
S
Salem Doom
The action replay will also let you do this, I hope the action replay has unlimited time days for Pikmin, I love that game but find 15 mins per ''day'' not enough :)
N
NeoBlade
The Action Replay should be out by now actually... I haven't led an active search for it though but I might start in the morning. It should be pretty interesting indeed.
N
NeoBlade
Hmm... I thought prog.scan was enabled via software... If it is indeed done from a hardware chip (it does make sense anyway)then it could be possible for a hacker to enable prog.scan for every NTSC game, much like on the Xbox. If thats the case then it would be very sweet ^_^
groundy
I hadn't thought of it like that before ;). I think it's a case of the hardware and software working together. Progressive Scan does need to be enabled in the software but the de-interlacing cannot be performed without some kind of hardware support as well. Who knows, it may all be performed insid ethe Component Cable's extremely clever D/A convertor.
N
NeoBlade
Hopfully a techno boffin could help us out and figure out a way to enable prog.scan for every NTSC game on the Gamecube. For the Xbox I've read its just a matter of selecting PAL or NTSC off a disk, and if you choose NTSC everything would be in NTSC prog.scan regardless if the actual game supports it or not. I'm tempted to try this out myself but I'll wait (a new sub is next on the hitlist). So far anyway there have been detailed hardware accounts of an NTSC Gamecube but none of the PAL version... I'll keep on looking around to see if anything interesting pops up.
N
NeoBlade
2manyconsoles, we know how to enable progressive scan on our import Gamecubes... Some titles even offer the option automatically without the B command. We were just talking about a possible progressive scan option on European (PAL) Gamecubes.
PAL Gamecubes with the component lead will offer an interlaced image only and not progressive scan. What I'm thinking of (along with other people) is that it might be possible for a PAL Gamecube to output progressive scan when using an NTSC game like Eternal Darkness.
You would have to use a suitable NTSC game (like Eternal Darkness, Wave Race, Rogue Leader II, etc) because they have the flags to enable progressive scan in the first place. The only way for us to test this theory though is to use a Freeloader/Action Replay. I just hope that either will be released. And soon.
Similar threads
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
