Gamecube connectivity to Panny 6
Discussion in 'Plasma TVs Forum' started by dwillis, Jan 5, 2004.
  1. dwillis
    dwillis
    Mar 19, 2003
    Bucks
    I have a question if anyone can help. I’m running my Gamecube through my amp via a composite cable to my panny6 via the component/s-video board. Unfortunately should you have the s-video cable connected (which I have) this overrides the composite. Other than removing the s-video lead every time does anyone know a way round this? I can’t seem to disable the s-video via the menus.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    No way round this if you have the 2 slot complete video board, except to connect your game cube better, RGB or YUV
  3. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Component cables are great for GameCube, and if you have Freeloader and US titles you can play in progressive scan.
    StooMonster
  4. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Only on some titles and not all.
  5. goliath23
    goliath23
    Jan 22, 2003
    40
    9
    Switzerland
    The best way for you is depending on the input boards you have.
    Assuming you don't have the Panasonic tuner box you could get the SCART input board and use a Nintendo RGB SCART cable to connect your Cube.
    How I did it: Gamecube -> Nintendo RGB SCART cable -> JS RGB to VGA converter -> VGA input.
    Probably not the chaepest solution, but it works great for me:D and leaves me the input slots for other purposes: I have a component board for my DVD and a composite / SVHS board for my VCR / tuner.
  6. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Before I bought the component leads I tried the GameCube scart via the JS-Tech RGB2YUV convertor, but found that the JS-Tech box didn't work properly with PAL60 (I like to play PAL discs at full speed).
    I run GameCube via iScan Ultra -- that has special modes to support games consoles -- and it's fabulous.
    StooMonster
  7. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    You and that Ultra - a match made in heaven...LOL ;)
    JJ
    P.S. I may have to buy one now too :mad: :D
  8. jmack
    jmack
    jasonjo
    there was a iscan ultra in the classified a few days ago
  9. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    Thanks jmack...found it.
    Not quite ready to purchase yet though (doh!!!) as need to demo first with Panny 6.
    Is £350 a good price?
    As I remember, you have NTL with a Panny 5 and use an Ultra - do you find it helps NTL PQ much?
    JJ
  10. dwillis
    dwillis
    Mar 19, 2003
    Bucks
    Guys
    Thanks to all for your prompt replies.
