Gamecube connection advice
Discussion in 'General Video Gaming Chat' started by daveb975, Nov 8, 2004.
  1. daveb975
    daveb975
    Oct 25, 2002
    4,334
    103
    London
    +370
    I have read through a few threads on the forums, but am still unsure what cable I need to connect my Gamecube to my system.
    I am looking for a component (pref) or RGB SCART lead, that will also allow me to output sound to my surround amp.
    It looks as though the official leads do not have separate sound connections. I have got Ixos leads for my PS2, but they do not make a Gamecube equivalent.
    What is everyone else using?
  2. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    You need 2 leads one for component, the other for connection to your amp
    I got my component lead from https://www.lik-sang.com
    The audio connection is the standard lead which came with the CG..Jim
  3. t-force
    t-force
    May 2, 2001
    1,852
    Southampton, UK
    +143
    Go for component if you can. It's a great cable, and can give Prog Scan output if you've got Freeloader and NTSC Prog-scan compatible games.
  4. bibooo
    bibooo
    Aug 15, 2002
    227
    Earth
    +11
    You have 2 options:
    1. RGB Scart from GC to TV, and if you want sound from your amp the TV should be connected to it via appropriate audio leads.
    2. Component from GC to TV, analogue audio from GC to amp (use the GC lead that comes with the console and leave the yellow composite disconnected or snip it off).
    There is no 1 lead solution :mad: .
    I went for option 2, I was very impressed by component feed (via official GC lead) slightly clearer/sharper than RGB scart. Also very handy for linking to my PJ.
    Hope this helps,
    bibooo
  5. daveb975
    daveb975
    Oct 25, 2002
    4,334
    103
    London
    +370
    Thanks for the advice.
    I hadn't realised that the component lead used the digital output.
    I have ordered the component cable from Lik-Sang - hope I don't get hit for customs charges!
