Gamecube component cable
Discussion in 'General Video Gaming Chat' started by daveb975, Nov 17, 2004.
  1. daveb975
    daveb975
    Oct 25, 2002
    4,264
    103
    London
    +349
    I have ordered one from Lik Sang, but they sent the wrong one.
    I have since read somewhere that newer PAL GCs have their digital output disabled, making component unusable anyway - is this true?
  2. Rob20
    Rob20
    Jul 3, 2004
    3,087
    +659
    As far as I'm aware, yes.
  3. daveb975
    daveb975
    Oct 25, 2002
    4,264
    103
    London
    +349
    Looks like I will have to sell the cable when I eventually get the right one, then!
    I am guessing there is no way to connect the Cube to a TV for picture, and a surround set up for sound without resorting to composite.
    The RGB SCART cable has no sound output as far as I can see.
  4. buzlightyear
    buzlightyear
    Oct 8, 2002
    949
    46
    London
    +119
    You could always try a SVideo video lead? The audio outs on that are seperate and that uses the normal input. I know this works on a PAL Cube with Freeloader running a US Game, but cant remember what happens if you run a PAL game.
  5. t-force
    t-force
    May 2, 2001
    1,842
    Southampton, UK
    +135
    If the PAL Cube is anything like the NTSC one, it's not a case of it being disabled, it's not there at all. If you've got a digital out, it will work.
  6. daveb975
    daveb975
    Oct 25, 2002
    4,264
    103
    London
    +349
    Mmm, My Cube has got one, so I will give it a try when I get the lead.
    Now it is just a case of getting an answer from Lik Sang on returning the other lead. Is their CS normally quite slow?
  7. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    I have the component lead from Lik Sang its superb you will need The original lead which came with the GC for the audio :thumbsup:
  8. daveb975
    daveb975
    Oct 25, 2002
    4,264
    103
    London
    +349
    Is your Cube quite new Jim?
  9. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    No its an early one why? The kids were playing Mario cart at the weekend on the PJ looked good to me on a 7ft screen!! Jim
  10. museumsteve
    museumsteve
    Jan 28, 2001
    7,867
    4
    Nth Hampshire
    +1,058
    newer NTSC GCs have had the digital output removed completely (not sure if PAL is the same). Also I thought PAL GCs couldn't output S-video.
  11. daveb975
    daveb975
    Oct 25, 2002
    4,264
    103
    London
    +349
    Thanks for your help on this.
    Apparently, all GCs manufactured after May 2004 have no digital output at all. If the socket is there, it will work.
    I was concerned as mine is one of the new platinum models, but it has a digital output so was obviously manufactured before May.
    Now just need to get the right cable from Lik Sang.
