gamecube 16:9 or 4:3
Discussion in 'General Video Gaming Chat' started by seven, Apr 4, 2002.
  1. seven
    seven
    I am thinking of buying a gamecube,what i want to know is, is it a 16:9 or 4:3 image? is it assignable to either on a set up menu or does it depend on the game? what type of connections are there for displays? i have a projector with component input and s-video
    which is the one i will be using as the dvd is in the component in .
    And what about sound is it DD.Can anybody give me any facts.
    LAST CONSOLE WAS SNES.
    Thanks for the help, Seven
  2. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    Most of the games I've got don't have a widescreen mode.
    It is game dependent.
    The import machine does have a 480p mode though. When a game supports it it will show a 480p (widescreen progressive). I can't use the Component outputs however so I can't vouch for which games support it.
    The english console ditches 480p mode in favor of a PAL60 mode I believe.
    Sound is through stereo jacks so at best can only be Dolby Prologic II (Rogue Leader supports this) most of the time its just DPL.
    Hope this helps
    Alex
  3. zcaps57
    zcaps57
    GameCube supports 480p progressive and widescreen.
    But to utilize this feature, software(game) has to support it, too.
    You need a component cable for 480p progressive mode. (UK version of GameCube won't handle progressive.)
    I have....
    Super Monkey Ball,
    Smash Bros DX (supports 480p)
    Pikmin (support 480p)
    Star Wars Rogue Squadron II (supports 480p)
    Virtua Striker 3 (supports 480p)
    Biohazard
    Only those two don't support 480p.
    P.S.
    The difference between progressive mode and interlaced mode is just amazing. Whole different graphics. :)
  4. DJ Sack
    DJ Sack
    Apparently, all PAL GC will support widescreen mode, which you can select to be on or off always, duno if its true, could well be, seeing as polygons are easier to squash to make them appear inwidescreen than normal pictures.
