Game not listed in all programs
Discussion in 'General Video Gaming Chat' started by laserbeam, Jan 10, 2018.
Tags:
  1. laserbeam
    laserbeam
    Aug 2, 2013
    1,107
    48
    Brighton
    +26
    I have just installed a game(or hope I have) but seem unable check to see if it plays as cannot find it.I had a problem installing it but by doing the following it seemed to have installed.
    1 I installed the disc
    2 Double clicked on Run Icon
    3 Clicked on setup.exe
    4 Install
    Now not sure whether it has installed or not and do I try and install it again.Cannot uninstall it as it is not listed.
    The game is Motogp13 and I have Windows 7.Any help appreciated
  2. Apsilon
    Apsilon
    Senior Moderator
    Sep 15, 2006
    14,681
    Manchester
    +7,965
    Check your Program Files (x86) folder under the root of c:\. Most games usually install to a folder name of the developer (Milestone in this case) rather than the name of the actual game
  3. laserbeam
    laserbeam
    Aug 2, 2013
    1,107
    48
    Brighton
    +26
    Had this message Motogp13 requires more free video memory.Playing with the current configuration can cause the game to malfunction .Please try closing some background applications.The graphics card I believe is a Intel(R) HD Graphics 3000.
  4. Apsilon
    Apsilon
    Senior Moderator
    Sep 15, 2006
    14,681
    Manchester
    +7,965
    What are you trying to run the game on? An Intel 3000 is several generations old, 7 years or so. And bearing in mind that Intel Chipset GPU's are not intended to run intensive games in the first place, you're going to struggle with this one even though the game itself is old.
    Have a look here on your system: Requirements Test and enter the game name and it'll check your system to see if it can run it.
    I don't know what your system is (I'm guessing it's an older i7/i5 which if that's the case isn't the problem) but, if your system is complaining about the GPU (which if it's an Intel 3000 - is built into the motherboard) I suspect you're going to need an older GPU installing separately. If the system is a circa i7 940 - 2600k/8GB etc, then I'd go for a Nvidia 680/780. It'll cost peanuts and run that game without breaking a sweat.
