Game cube + S Video
Discussion in 'General Video Gaming Chat' started by slingshot, Mar 19, 2003.
  1. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Thinking of buying a cube now Argos are selling them cheap, can I get S-Video out of it ?
    Done a search on the forum and couldn't find anything just component (possible but means unhooking something else) or RGB (not possible at all).
    Slingshot
  2. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    I'm sure you can. Mine is a Jap/US one and it works with S-vid. I'm sure it's the same for all regions.
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    A UK GC will only output composite video, RGB or component video (though it's digital video output).
  4. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Retro is correct.
    slingshot - you've been finding information on NTSC Cube connection methods.
  5. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Thanks guys you've saved me 80 quid. I'll just stick with the PS2 for now, I could put the PS2 through S-Video and the GC through component. But it stops looking that cheap by the time I've bought extra leads for both. Plus the PS2 will at least do prog scan through component. or bought a component switch box.
  6. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Oops, sorry. Glad to see somebody corrected me.
    PS2 does do progressive scan, but as far as I know hardly any games support it.
  7. jb9
    jb9
    gamcube does HDTV if your tv supports it............, but i'd hardly think that what lead you need is an issue for making you not buy one if you want one.........
  8. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    It is if you have limited inputs on your display device, and S-Video is the only option.
  9. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    I use this component switcher. But as you say, once you've got one of these and a component lead suddenly the Cube doesn't seem so cheap.
    BTW, I think Tokuda on www.ntsc-uk.com does the GC component cable for £25.
  10. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Thanks Willy but that appears to be a S-Vid switch box, had a quick search but couldn't find a component switcher at Keene.
  11. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    It is, but it supports 75ohms, which means it's fine for component. I use it, and it does progressive scan just fine.
