Game Advance SP Region Coding?
Roland @ B4
Established Member
Can anyone tell me is there such a thing as regional coding on Gameboy Advance SP.
Or in other words will software run on gameboys bought in other countries. or visa versa. ;)
Thanks in Adavance:D :rolleyes:
Matt Horne
None whatsoever.. you can play what u like from alround the world. No GB has ever had a region lockout..
Matt
Roland @ B4
Established Member
Oh if the rest of the AV industry was the same how easy life would be.
Many thanks
Paul Williams
Established Member
Language, is however a bit of a barrier if you get some of the Japanese ones.
Paul
AML
Having said all this, I bet the PSP will have some kinda region lock! I doubt the Nintendo DS will since it should be backwards compatible with the GBA and GB.
GeorgeShadow
yes, i think PSP will probably having region coding problems. it is very stupid that DVD's over the world are using region locks at the 1st place, there is no point on doing that at all :thumbsdow
🎬 The Creator & Reptile, Guardians 3, The Others & Cutthroat Island 4K & Best/Worst Renny Harlin
Back
