Gallo Nucleus Micro and banana plugs?
Discussion in 'Home Cinema Speakers' started by danfrance110, Aug 29, 2004.
  1. danfrance110
    danfrance110
    Can anyone tell me if when using the nucleus micro's with the wall mounts there is a problem using banana plugs? I've heard that you can't use standard banana plugs with the wall mounts as there isn't enough space between the wall and the connections? Can someone help?
    Dan
