advice please, just become crazy with speaker advice from richersound tip, i am going to put gale speaker spike on my floor standing eltax linear response power tower.the question is that is it safe to drill a hole at the corner of botton to fix the spike.( i don't have original spike) bigscreen
Yes you should be fine. I put spikes on my old eltax Mill 200's with no problems. If you still worried put them in the corners where they will screw into the side walls.
