Gale 3080 Subwoofer
Discussion in 'Subwoofers' started by Johndm, Feb 1, 2003.
  1. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    I'd always thought my Mission 773e's could handle the low stuff, but impulse bought a Gale 3080 sub from RS recently.
    Any thoughts on this sub? I really should have done some 'proper' reading on the subject before buying.
    It seems......well........sort of OKish, but a bit underpowered?
    suggestions for an upgrade maybe............
  2. gimli
    gimli
    You won't like it but my suggestions for an upgrade would be "almost anything else"
    There is no such thing as a good cheap subwoofer and this is a subject that has been covered many times before.
    The cheapest decent sub that would make a significant difference to your system is the Velodyne CHT-10 which is available through this forum's power buys at £325.
    There are a large number of reviews on this product from forum members available on this site.
  3. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Yeah, I thought I'd wasted £150 before I even got it home!
    Still, it makes some sort of 'boom boom type noise', so I just need to convince the missus that we NEED to upgrade.....purely for the sake of the reciever.
    Will check out the CHT-10.....Thanks:D
