gale £120 surround spks to go with sony 1070?
Discussion in 'Home Cinema Speakers' started by wattman, Mar 7, 2002.
  1. wattman
    wattman
    i was thinking of buying a set of 5 gale surround speakers from richer sounds. the price seems a bit cheap but they look like the sort of style i`m looking for in the picture(in what video&tv). can anyone give me any "previous experience" views about these speakers. i have a feeling most will say get more expensive ones, but can you honestly tell the difference?? they will be getting matched with the 1070,hitachi 24"pro-logic & hitachi vcr.. i am also in the process of deciding which dvd to buy:clown:
    ta
    wattman
  2. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    You can most certainly tell the difference between speakers and although it is a generalisation the more you pay the better sound quality.
    If your budget limit is £120 then they are probably worth buying but if you can afford more the sound will be more rewarding.
  3. mjn
    mjn
    May 24, 2001
    22,723
    Herts, England
    +10,868
    speakers proberly have the greatest effect on the end sound of your system!
