Galaxy Quest dts problem
Discussion in 'Movie Forum' started by steve tyler, Aug 31, 2000.
  1. steve tyler
    steve tyler
    Jul 14, 2000
    268
    Chigwell,Essex
    +15
    Just received the said disc and cant seem to access the dts soundtrack.the case says that its dts but the disc doesn`t, only DD.Have i got the wrong disc or is there something else i have to do to get it.
    thanks for any feed back rgds steve
  2. Guest
    It must be the disc because my copy clearly has DTS printed on the disc itself.
    Send it back.
  3. Guest
    1) Does you player support DTS (if it's a PC then it is very unlikely that it will)
    2) Do you have a DTS decoder.
    3) Is it playing a DD5.1 or just plain DD2.0 Surround, if it is DD5.1 then you have the DD5.1 version that has been sent to you in the wrong case.
    4) The DTS version will start up with a menu that lets you choose DTS or DD2.0 Surround.
  4. steve tyler
    steve tyler
    Jul 14, 2000
    268
    Chigwell,Essex
    +15
    Thanks chaps.Yes i have got dts decoder and yes i am getting dd 5.1.going to send it back .
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    What player do you have?
  6. steve tyler
    steve tyler
    Jul 14, 2000
    268
    Chigwell,Essex
    +15
    I have got sony 7700 & ax1 amp.
  7. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Looks like a problem with the disc then.
    But make sure your box/label says "DTS" because there are IMHO two versions, one DD and one DTS.
    The DTS works fine on my Yamaha player and the soundtrack is selectable via the discs menue. If it's not there you got a non-DTS disc!
