Question Galaxy Note 10+ with Spigen Case - compatible Screen Protectors
DerJohann2903
Hey Guys
My Note 10+ has a screen Protector out of the box. But i'm not satisfied with it since it is out of plastic and i already have a frew minor scratches.
Now my Question is : I'm looking for a strong screen protector that fits my case. Lots of protector companies write "Case friendly" but my case fits reealy tight that's why i'm a bit concerned that my choice won't fit.
I hope I will find someone with a Spigen Case aswell as a Note 10+ :)
Cheers !
BM08
It doesn’t matter how tightly your case fits, it’s whether the case is leaving a gap for the screen protector. Usually most screen protectors are slightly smaller than the phone screen to allow for cases.
Chances are, if the plastic one that’s on it now fits with the case, then so would a new glass protector, as they are the same size usually. Just look at the pictures before buying to see if there’s a gap. Most companies I’ve bought from on amazon allow returns and refund if your not happy too.
BM08
Heard good things about white stone dome. Might take abit longer to install than a normal screen protector but if the fit is better then it’ll be worth it
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
