"Gain" of a screen ?
Discussion in 'Projectors, Screens & Video Processors' started by Nick_UK, Jan 12, 2005.
  1. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I have seen people quoting "gains" of screens here - i.e. "this screen has a gain of 1.2:1"
    Can someone explain what this means ? Surely you can't have more light relected back than what has been projected ? :confused:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    no see the stewart screen site they have a good explination.....
  3. Cheddies
    Cheddies
    Jan 11, 2005
    41
    "What is gain and why is it important?
    Gain is the concept of a relative ratio of brightness between a sample and a standard (magnesium carbonate). Gain used to be a very important issue because projectors had low lumen output. The Gain of 2 would be twice as bright as the standard (which looks similar in appearance as a sheet of paper). Since the light is reflecting back to the audience in a front projection screen, the higher the gain is the closer one has to sit directly in front of the screen, whereas if you had a lower gain screen you might be able to sit off axis as far as 40 to 60 degrees and still have a quality image."
    from http://www.diytheatre.com/faq.htm#Anchor_Technical_1
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Thanks everyone :smashin:
