Gain Match in Power Amps
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by stephenc, Jul 17, 2001.
  1. stephenc
    stephenc
    Sep 26, 2000
    1,427
    116
    Dunfermline
    +510
    I am thinking of buying a 2-channel power amp (for music) to compliment my Sony STR-DB930.
    However, when matching the gain of the power amp to the Sony, to get the same volume, does both the Sony and the power amp need to have gain mactching or just the new power amp??
    Any help is most appreciated,
    Stephen. :confused: :confused: :confused:
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Only the power amp would need gain matching.
    If you are going to power your fronts speakers soley from the new power amp gain matching isn't so much of a problem. This problem only arises when you start bi-amping with external power amps.
  3. stephenc
    stephenc
    Sep 26, 2000
    1,427
    116
    Dunfermline
    +510
    What is bi-amping??
    Stephen. :eek: :eek: :eek: :confused: :confused:
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    2 amps per speaker, one to drive the bass/mid driver, one to drive the tweeter.
    In a stereo setup you would need then 4 channels of amplification, if you want to bi-amp your 5.1 setup you will need 10 channels (e.g. two 5-channel amps).
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Oh, the speakers must support this, i.e. have 2 sets of input each (which are linked in a 'normal' setup using a metal plate or short cable).
    Now take a guess what tri-amping means!? :D
  6. stephenc
    stephenc
    Sep 26, 2000
    1,427
    116
    Dunfermline
    +510
    Thanks Reiner,
    I gues it is OK to power bi-amp'ed speakers (my mission 773e's) support this using the one amp.
    For example, I have the 4 channel speaker cable, however it all comes from one amp at the moment, but it splits to drive the bass and tweeter units.
    If I was going to move to a power-amp, I was just going to do the same again.
    SJC
  7. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Stephenc: It sound like you have your Missions bi-wired at the moment. This is fine.
  8. stephenc
    stephenc
    Sep 26, 2000
    1,427
    116
    Dunfermline
    +510
    Hi Retro,
    I knew their was a term that I couldn't remember this morning, bi-wired :)
    One day I'll get all this, it used to be so easy, walking into Dixons and walking out with the kit which looked the coolest, now it's all demo's, web-reviews etc. etc.
    Stephen. :D
