Gadgets Skewed and Can't access webmail !!
Discussion in 'Microsoft Windows' started by vwdubman, Apr 30, 2007.
  1. vwdubman
    vwdubman
    Feb 26, 2005
    895
    +57
    Wonder if anyone can help as my gadgets (which were working perfectly) are looking as in the pic below and for some reason none of my webmail accounts are loading their pages.
    All that I had done was upgraded my aVast to pro edition and after it asked for the computer to restart it caused the above problems. I have tried stopping avast and that doesen't cure anything.
    [​IMG]
  2. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    Have you tried uninstalling Avast completely?
  3. vwdubman
    vwdubman
    Feb 26, 2005
    895
    +57
    That's probably the only option left. I will try it.
  4. England2Canada
    England2Canada
    Apr 22, 2007
    282
    Ontario, Canada via LDN UK
    +15
    I think there is a problem with the screen resolution, make sure it's 1024x768 or 3whatever that resolution is
  5. vwdubman
    vwdubman
    Feb 26, 2005
    895
    +57
    All sorted thanks to system restore. Dont know what caused the problem but its all sorted now :thumbsup:
